jrman523
Aug 17, 2017Aspirant
Reday Nas Option missing
HELP!!!
I just got the R7900 Nighthawk and i wanted to use my extra 1TB extrenal hdd as a NAS device, i know this router is capable of it that is why i got it, but the issue is that i do not see the option under routerlogin.net but i see it under my network genie. and i also have an account with netgear readycloud but i can not set up an device on NAS due to not being able to see the option there. Please help me, as i have reset the router at least 10 times and the issue is still there.
- Yes the nas is connected via usb but I figured it out it was not registered so it was not working at all once I register readycloud account it all worked fine
You don't have a ReadyNAS at all, so your problem is something else - either
- connecting your 1 TB drive to your router, or
- accessing your 1 TB remotely with ReadyCloud
Can you tell us which of those problems you have having?
