lifequitin
May 21, 2015Follower
Region change?
I bought R8000 from US during my travel and i want to use it within EU. Region setting can't be changed from admin interface and wireless performance is sluggish because of the low power compared to ...
- Nov 13, 2015
Hi porschaman,
The region is locked based on the place it was manufactured and also the firmware loaded on it. If you want to change it, you may try loading a different firmware. Check the suppot site (Support.netgear.com).
JamesGL
Community Team
Darshaannawab
Nov 03, 2015Aspirant
My netgear router also has region grayed out, please help I'm from Asia
JamesGL
Nov 04, 2015NETGEAR Employee Retired
- porschamanNov 13, 2015Aspirant
Please help! Recently purchased R6300v2 thru Amazon. The Genie's Region is locked on North America. Can you help me change it to Asia. Thank you all.
- JamesGLNov 13, 2015NETGEAR Employee Retired
Hi porschaman,
JamesGL
Community Team
Thnx James. I'm not sure I follow you on the change firm ware thing. But I did contact live chat support last week, and they (call center! somewhere!!) could not provide answer?
Thanks anyway for trying to help.
TA
