lifequitin
May 21, 2015Follower
Region change?
I bought R8000 from US during my travel and i want to use it within EU. Region setting can't be changed from admin interface and wireless performance is sluggish because of the low power compared to ...
- Nov 14, 2015
Hi porschaman,
The region is locked based on the place it was manufactured and also the firmware loaded on it. If you want to change it, you may try loading a different firmware. Check the suppot site (Support.netgear.com).
JamesGL
Community Team
JamesGL
Nov 14, 2015NETGEAR Employee Retired
Hi porschaman,
JamesGL
Community Team
porschaman
Nov 14, 2015Aspirant
Thnx James. I'm not sure I follow you on the change firm ware thing. But I did contact live chat support last week, and they (call center! somewhere!!) could not provide answer?
Thanks anyway for trying to help.
TA
- netwrksNov 14, 2015Master
porschaman wrote:Thnx James. I'm not sure I follow you on the change firm ware thing. But I did contact live chat support last week, and they (call center! somewhere!!) could not provide answer?
TA
The router runs on firmware. JamesGL is suggesting reloading a fresh copy of the firmware, to see if the issue can be resolved. Go to the Netgear_Support_Page click on networking icon locate the firmware, download to your desktop / laptop, and reload the firmware, When you have completed this step reset router to factory default (which you should have done in the first place as you did buy it used) and reconfigure the router.
- porschamanNov 14, 2015Aspirant
Thnx for input. Purchased brand new via Amazon US site.
- CarlinglabelMar 12, 2016Aspirant
Hi
I left the router in box long ago, as all attempts failed to change region.
Ref yr recom to load new firmware, this has not worked also.
Reason, the new router has the genie download latest firmware version in it, and it is exactly the same as the latest one avail on the netgear website, i.e. 1.0.4.2_10.0.74
So how downloading firmware version from netgear site, differ from what the Genie has updated on the router itself, same name and version!
Thanks anyway for trying and the moderator of netgear to eheelp.
- JamesGLMar 14, 2016NETGEAR Employee Retired
Hi Carlinglabel,
What is the region on your router? Where did you purchased the router? Normally the country of purchase will be followed as the region of the router. If it is North America, then the region on the router should be North America.
