lifequitin
May 21, 2015Follower
Region change?
I bought R8000 from US during my travel and i want to use it within EU. Region setting can't be changed from admin interface and wireless performance is sluggish because of the low power compared to ...
- Nov 13, 2015
Hi porschaman,
The region is locked based on the place it was manufactured and also the firmware loaded on it. If you want to change it, you may try loading a different firmware. Check the suppot site (Support.netgear.com).
JamesGL
Community Team
Cognizant1
Jan 22, 2016Tutor
I live in IL and bought the Nighthawk r7000-100pas from Dell. (Don't offer 100nas) do I need to change anything and if so why don't they sell the North America version when most purchase in the USA? Thanks
