lifequitin
May 21, 2015Follower
Region change?
I bought R8000 from US during my travel and i want to use it within EU. Region setting can't be changed from admin interface and wireless performance is sluggish because of the low power compared to ...
- Nov 13, 2015
Hi porschaman,
The region is locked based on the place it was manufactured and also the firmware loaded on it. If you want to change it, you may try loading a different firmware. Check the suppot site (Support.netgear.com).
JamesGL
Community Team
Fairytail
May 22, 2015Virtuoso
The reason why the region is greyed out because it is manufactured for the place where you purchase the unit. That is why there are different firmwares uploaded on NETGEAR's site for different region.
