stargate69
May 27, 2021Tutor
Replace Nitehawk AC1900 R7000
The X6S seems to have better specs than the X6 but is $30 less!!??? I'm happy with AC1900, but would I like AC5400 better?? I'm not a gamer, but I could use one or two more ethernet 'outs' ...Thanx f...
- May 30, 2021
If it was me, I'd look at the R7800. Its around that price
If you want to see actual tested performance. I'd recommend reading a few testing sites. Smallnetbuider does a great job and ranks them and goes over them. Its a great resource.
May 28, 2021Guru - Experienced User
Are you comparing the R8000P to the R8000?
Or what exact devices are you comparing? (hint, AC**** are speeds, not models)
And are you just wondering about the differences?
stargate69
May 28, 2021Tutor
I need to replace my 7yr old AC1900 R7000, it has a bad 'glitch' ....I was wondering why the price difference between those two particular models?? And, don't get me started, ...why are they called 'gaming routers' !?? Would I be happy with an AC3200 ?? Or go all out and get AC5400!?? I'm not a gamer... would I notice a tri-band?? I would buy something in the $300-400 range....twice what my R7000 cost back then...Hope this helped ...Thanx again ... B C
- plemansMay 30, 2021Guru - Experienced User
