stargate69's avatar
May 27, 2021
Replace Nitehawk AC1900 R7000
The X6S seems to have better specs than the X6 but is $30 less!!??? I'm happy with AC1900, but would I like AC5400 better?? I'm not a gamer, but I could use one or two more ethernet 'outs' ...Thanx f...
  • plemans's avatar
    May 30, 2021
    If it was me, I'd look at the R7800. Its around that price
    If you want to see actual tested performance. I'd recommend reading a few testing sites. Smallnetbuider does a great job and ranks them and goes over them. Its a great resource.
    https://www.smallnetbuilder.com/tools/rankers/router/view
