stevenfry
Aug 27, 2022Follower
Replacement equivalent for Nighthawk X10 AD7200 (R9000) ?
Hi,
The fan in my Nighthawk X10 AD7200 Smart WiFi Router (R9000) has failed
and I need to buy a new router. Can someone please tell me the current equivalent product
from Netgear? I need the fastest and most powerful router Netgear sells because I have a large number of 4 mbps streaming cameras and most routers will not handle this.
I also need to support about 40 attached devices.
Thanks
Steve
1 Reply
How much area are you covering?
Are you looking for single router solutions or a mesh solution?
A mesh might be beneficial as then it spreads the load out a bit (if your area is big enough).
Flagship routers: RAXE500 (triband with 6ghz), RAXE300 (triband with 6ghz but a little lower performing), and the RAX200 (triband but 2x 5ghz instead of a 5ghz and 6ghz)
You could look at the mesh systems like the RBKE963 or RBK853
