Kyra1
Jun 22, 2022Aspirant
Reset to Default Settings
Was having a problem with mu NightHawk router. i contacted IT and was to to reset the router and change the SSDI and password which did not solve the problem. So I am wondering if there is a way to reset to the original settings. Thanks for any help
1. what router do you have? (hint, the label will have the model number on it)
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. what actual issue are you having? Details help as a reset might not be whats needed to fix the issue
- Kyra1Aspirant
My HP printer will not connect to the wireless network. I have added all the new settings that were changed though it still will not connect. The printer worked fine before every thing was reset. My computer does connect to wireless on same network
Well, you answered #4
Got a few more answers to the questions?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
