networkdude
Feb 18, 2016Follower
Restore process needs to work for future firmware updates
I consider it a competitive disadvatage that the restore process for my Netgear wireless R7000 router (and by all indcations, all Netgear routers) require manually reentering configuration informatio...
- Feb 22, 2016
Thank you very much!
We would normally advise to use the backup and restore feature for ease of reconfiguration.
It just so happen that our engineers found that there is something on that firmware release that made it impossible to just use the backup and restore feature hence they advise to do manual configuration.
Moving forward, NETGEAR has taken note of this and will eventually use the restore function again for easy reconfiguration.
ElaineM
Feb 18, 2016NETGEAR Employee Retired
Hi networkdude I apologize for any inconvenience this may have caused you.
Rest assured that your input will be forwarded to the management.
Thank you and we appreciate your feedback.
- Mr_DJFeb 19, 2016Apprentice
I support this suggestion VERY much. So happy to read a quick responds from a Netgear affiliate! ;-)
In these modern times, where the routers have increased functionality and onboard memory. A feature such as this, should be easy to add and really be a common industry standard feature, as there really is no excuse not to do it. And as said above, would make future firmware updates suddenly become a breeze, when it comes to re-configure the router back to the users own preferences.
A win-win situation, as there is no cons to such a feature! ;-)
- ElaineMFeb 22, 2016NETGEAR Employee Retired
