networkdude's avatar
networkdude
Follower
Feb 18, 2016
Restore process needs to work for future firmware updates
I consider it a competitive disadvatage that the restore process for my Netgear wireless R7000 router (and by all indcations, all Netgear routers) require manually reentering configuration informatio...
  • ElaineM's avatar
    ElaineM
    Feb 22, 2016
    Thank you very much!
    We would normally advise to use the backup and restore feature for ease of reconfiguration.
    It just so happen that our engineers found that there is something on that firmware release that made it impossible to just use the backup and restore feature hence they advise to do manual configuration.
    Moving forward, NETGEAR has taken note of this and will eventually use the restore function again for easy reconfiguration.
