NHStuff's avatar
NHStuff
Restrict Firewall exception to a specific incoming IP
I'm looking to open up Port 22 (SSH) for incoming traffic from a specific IP only (not open to the world).
Can't seem to find the proper firewall/router configuration for this.
Suggestions?
  • Not possible on stock firmware. Well, it's doable, but you'll need to mess with iptable rules
    • NHStuff's avatar
      NHStuff
      Can you recommend an alternative model (or Brand) that's more suitable for this need?
      I have this requirement and will be looking to replace the R7000 with something capable of handling this traffic restriction.
      Thanks!
      • microchip8's avatar
        microchip8
        Master
        AFAIK, no other brand supports that. Also, we can't recommend other brands here as there were people banned by doing so
