Laurent78's avatar
Laurent78
Reverse lookup not working ?
Hi.
My model is AX1800 (not sure why it isn't in the list).
I do not succed to use the local internal resolver on my Netgear (DHCP activated). The local names that I've set up in the admin interface are not provided on PTR request.
For example (the answer should be SCP62328):
dig -x 10.0.0.18
; <<>> DiG 9.10.6 <<>> -x 10.0.0.18
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 10564
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;18.0.0.10.in-addr.arpa. IN PTR
;; Query time: 35 msec
;; SERVER: 10.0.0.1#53(10.0.0.1)
;; WHEN: Mon Nov 29 09:31:08 CET 2021
;; MSG SIZE  rcvd: 51
What am I doing wrong ?
Thank you.
Laurent
  • Make sure that your reverse DNS record matches the host name of your server. Make sure that a regular DNS lookup for the domain you have designated as the reverse DNS record entry returns the IP address in question. For example: If 70.32. 86.172 has a reverse DNS record of example.com.
    • Szabo52's avatar
      Szabo52
      1. Make sure that your reverse DNS record matches the host name of your server.
      2. Make sure that a regular DNS lookup for the domain you have designated as the reverse DNS record entry returns the IP address in question. For example: If 70.32. 86.172 has a reverse DNS record of example.com.
      garageband
      • Laurent78's avatar
        Laurent78
        Sorry i am still learning all this network stuff.
        I was thinking the router would do this job for me.
        My goal is to simply identify my devices on Adguard Home without static adress for all my devices. Is it possible to achieve that?
