GaACETech's avatar
Dec 22, 2022
Router - IP address range
Dealing with a new router to replace the current internet provider modem/router for a small business.  But the business has about 6 IP addressed printers, plotters, and scanners.
I normally use the 192.168.1.nnn address range when install new routers.  However, some of these devices will be a pain just to figure out how to change the IP address.
Can I use the modem/routers 10.1.10.nnn address space so that none of the IP addresses need to be changed?   I know the modem needs to keep the 10.1.10.1 address (I guess) so I would start the DHCP address range at .2-250.
Is there a issue with this that might cause it to crash?
Thanks!
Darryl
  • plemans's avatar
    Your description wasn't that clear but you can use whatever IP range you prefer.
    And devices shouldn't need to get their own IP address. when they connect to the new device, it assigns them an IP address.
    • GaACETech's avatar
      GaACETech
      Guide
      Thanks for answering.
      I'm replacing the current modem/router combo (from internet provider) with a newer router.
      The scanners, printers, and plotters all have static IP addresses.  This equipment was setup by a the respective vendor.  Note 2 of the plotters have built-in laptops where the images are stored and processing for printing.
      I would rather not have to change the static IPs on these devices/laptops.
      My question is can I use the current 10.1.10.nnn, with 10.1.10.1 being the modem/router, address range?  I use the 10.1.10.1 to login to the Arris modem/router.  So I would think I need to start the address space with .2 with.
      Thanks for the help.
      Darryl
      • michaelkenward's avatar
        michaelkenward
        It still isn't that clear to me what you are doing, with that mix of IP addresses 10.1.10.1 and 192.168.1.1
        What were those fixed IP addresses? 10.1.10.XXX or 192.168.1.XXX?
        If the IP address of the current modem/router combo? 10.1.10.1, is that what the devices were fixed to work with?
        By default, your R7000 will try to squat on an IP address of 192.168.1.1
        That isn't likely to be much use to devices with addresses fixed to work to the 10.1.10.1 router.
        Putting the new router on 10.1.10.1 might be the easiest option.
        If you want the R7000 simply to spread the wifi, then using that in AP mode would let the existing modem/router manage the network.
