Webermar
Jan 11, 2022Aspirant
Router and Extender Set Up
I cannot get my Nighthawk Router to connect to my network. I have rebooted several times with no luck. I am not tech savy so I am sure I do not no how to set any of the settings. I also have a Netgear extender which I need to connect as well. I need some help!
I have the above Router and a AC1900 Extender
Mark
1. what modem/gateway are you connecting to?
2. what firmware is on the R8000P?
3. Is this a new purchase? or what changed?
4. if its new, you get 90 days of free support through netgear from date of purchase.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.5. What extender do you have? AC1900 is a model
I'd focus on getting the router connected and working first. then worry about the extender.
If you have a simple modem, power off the modem and router and disconnect them from everything for 2 minutes.
the connect the coax back to the modem and power it on.
wait 2 mintues
connect the modem to the wan port on the router and power the router on.
Wait to minutes.
Attempt setup on the router.
- WebermarAspirant
Thank you for replying so quick. Let me attempt to answer your questions:
It is the modem supplied to me by my ISP with their brand on it.
I am not sure. It shows it needs an update, But I cannot get on the net to update it.
No, I bought it in 2000. I tried to use it before and it just wouldn't work for me so I just used my ISP's service. I am just now trying to fix it since I have the time. I am also trying to punch the signal outside of the house hence the extender. But I agree with you. I am concentrating on the router for right now.
They weren't much help when I bought it and I simply got frustrated with it. I was going to hire someone to come out and fix it, but that takes almost a house payment...
AC 4000 Tri-Band WiFi Router Model # R8000P
Agreed
wait 2 mintues
Wait to minutes.
No Luck. Did this 2x with no success. I have pluggedf my computer directly into the router and still cannot get online.
It is the modem supplied to me by my ISP with their brand on it.----And what model number is it? it should be on the label.
I am not sure. It shows it needs an update, But I cannot get on the net to update it.---A firmware version number helps. And you can update off-line manually. but its nice to know what version you're starting from.
No, I bought it in 2000. I tried to use it before and it just wouldn't work for me so I just used my ISP's service. I am just now trying to fix it since I have the time. I am also trying to punch the signal outside of the house hence the extender. But I agree with you. I am concentrating on the router for right now.----I doubt it was 2000. its not a 22 year old device :)
AC 4000 Tri-Band WiFi Router Model # R8000P---that'd be the router model. You put you have an extender. what extender is it?
