AlKiecker
Nov 09, 2020Aspirant
Router blocks website we need to get to
Nighthawk AX6 6-stream AX5400 WiFi Router (RAX50) How do I configure my router to allow access to a specific website that Armor is blocking access? This is a new router, installed 10/9/2020. ...
AlKiecker
I should have mentioned ... when I take the AX5400 out of the loop and direct connect the computer to the modem, we have no trouble accessing the website.
AlKiecker
Problem seems to have gone away.
Section 4 of the User Manual seemed to apply so I logged on to the router as admin and went to the security section. There were no sites, keywords, etc that were to be blocked. I went through everything and made sure that nothing was set for blocking but still did "apply" even though there were no changes made. I did change the schedule. It was set to off (no schedule), but I still unchecked all the days and time for blocking.
I don't see that I actually changed anything, but it is working now.
