Martinc13
Nov 11, 2020Follower
Router CR700
I have a TP Link router CR700 which is running my Mediacom cable.I want to replace with Nighthawk.Which model would you recommend.
1 Reply
- DarrenMSr. NETGEAR Moderator
Well, you may need to keep the CR700 and use it in modem only mode. But I suggest looking at our wifi 6 routers.
https://www.netgear.com/landings/wifi6/
DarrenM
