Ryan15715
Jan 27, 2018Aspirant
Router Not working after having a other control panel than switching back to the regular
So i used to have a regular control panel routerlogin.net But Then I switched the firmware to dd-wrt Firmware But a month later I got to download the regular Netgear Firmware for my Model to put the regular firmware back but then That's when The router Screwed up it said it has no IP anymore and saying no internet access I need Help
See previous answer. Talk to the people who know about DD-WRT.
> [...] I got to download the regular Netgear Firmware for my Model to
> up
Not a very detailed description of what you downloaded, or what you
did with it (whatever it was).
> [...] it said it has no IP anymore [...]
_What_ said what, exactly, when you did what, exactly?
> [...] I need Help
So do the non-psychics in your audience.- Ryan15715Aspirant
OK So a while back I switched to the DD-WRT Firmware but then i wanted to switch back and i did with the downloaded firmware from Netgear but then i screwed up my router and i said whenever i connect to it No IP and No internet access
- Ryan15715Aspirant
If you are still running with dd-wrt firmware then you'll probably have better luck if you go to one of the places where experts in that firmware hang out and seek advice on how to revert to the factory firmware.
