SteZauro's avatar
SteZauro
Follower
Dec 19, 2020
Router R7000 as a bridge (with double authentication)
Hi all!
I have this question:
is it possible to connect the R7000 to a WIFI HOT SPOT  (WOW FI FASTWEB)  that is usable with double authentication  (when I connect to WOW FI Fastweb, I must put  username+password)
In other words, setting the R7000 router as a bridge that gives internet connection through the Hot Spot Fastweb (but important, we have to set that the key to use the hotspot is made by username & password -  not only a password)
I hope this is possible!
Otherwise, I have to put the router in the trash can..  :(
Waiting for Your help!
Thanks!
Stefano
(and a big smack to Elvy)
1 Reply
