IvorJohn's avatar
IvorJohn
Follower
Dec 23, 2020
Router recycling
Does anyone know of any ways to reuse or repurpose a functioning netgear router? Thanks!
  • Depends on what you want to do and which router model you have. If it's a pure router, you can turn it into an Access Point to extend coverage
  • michaelkenward's avatar
    michaelkenward
    The C7000 listed in your footer is a cable modem/router. This means that, unlike most DSL modem/routers, it is not easily reused as an wireless access point or as a standalone router, unlike. You may be able to do it, but the device doesn't come with simple instructions in the manual.
    The first thing to do is this:
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    • wcalifas's avatar
      wcalifas
      Prodigy
      you could use it as an access point, I used my old netgear dsl/router as an access point. Mine is a little older so don't know if converting it to an access point is different than mine. Of course you need to disable the dhcp part of it.
      • tomasz_ng's avatar
        tomasz_ng
        Guide
        You can also just give it away to someone who needs one. No need to clutter your home. I use Freegle to advertise when I have something to give away for free, and there's almost always someone who does within a day or two.
