Chief22
Sep 29, 2025Follower
Router Speed
Download speed from modum is 450 mbps. Download speed from router is 100 mbps. Router is a Nighthawk model R7000. Is this a normal loss in speed or do I need to upgrade my router? Upload speeds a...
CrimpOn
Sep 29, 2025Guru - Experienced User
Chief22 wrote:Download speed from router is 100 mbps.
Sorry to nit pick, but...... How is the download speed from the router being measured? and... is "100mbps" less than 100 (such as 94mbps) or even 1mb higher than 100?
When two devices with Ethernet adapters are connected with an Ethernet cable, the electronics built into the physical adaptors negotiate the highest speed that can be supported. When the link is negotiated as 100mbps, then it is physically impossible to transmit any higher speed than "mid 90's".
Page 12 of the User Manual describes how the Ethernet LAN ports indicate the connection:
Unfortunately, it does not appear that the WAN port has a similar capability.
