Chief22
Sep 29, 2025Follower
Router Speed
Download speed from modum is 450 mbps. Download speed from router is 100 mbps. Router is a Nighthawk model R7000. Is this a normal loss in speed or do I need to upgrade my router? Upload speeds a...
Sep 30, 2025Guru - Experienced User
Chief22 wrote:Download speed from modum is 450 mbps. Download speed from router is 100 mbps.
To make CrimpOn's hint more explicit: I suggest ruling out the cabling first. One possibility is that the connection is negotiating fast ethernet for some reason.
So try a different cable. If you have spare ethernet switch handy, you could also try putting the switch between the modem and the router, and see if that makes any difference.
