dave8345's avatar
dave8345
Follower
Jun 24, 2021
Router to Switches to NAS ?
I am in the process of setting up a home network.
starting with a Bell Canada HomeHub 3000 - has WiFi and 4 ports.
1 port is out to my GS308P.
on the GS308P port 8 = Router... Port 7 = Laptop.. Port 6 = Desktop. 5 = open  ( keeping the 4 POE ports free for IP cams later )
all working fine.
To add more ports I would like to add a GS308E (or better if you recommend) so I can feed other desktops +
i also have a Synology DS720+ ( not set-up yet )
Q1, should I plug the new GS308E into a free port on the router, or into the existing GS308P?
Q2, shoud the 2 ports on the NAS plug into the 2 free port on the router, or into the GS308E
Would appreciate any feedback that makes the set-up easy, but protecting the family photos on the NAS is more impoertant.
Thanks team.
Dave8345
1 Reply
  • schumaku's avatar
    schumaku
    Depends on the intended network layout. If both switches are near to the router, I would suggest a "star" topology, and connect each switch direct / individually to the router.
    Start with only one LAN port of the NAS, typically there is kind of a numbering on the NAS, use #1 to start with. Using multiple network connections for link aggregation requires additional configuration, probably on the NAS, probably on the switch [both links must go to the same switch!] and the NAS.
