zambeezi
Jan 01, 2018Tutor
Routerlogin.net - constant password recovery
Hi,
EVERYTIME I try to log in (routerlogin.net) I have to use password recovery. My username and password is correct.
I log in... password recovery. If I log out and log in again 10 minutes later.... password recovery!
There has to be e batter/easier why to access the router.
zambeezi wrote:Hi,
I just bought a Netgear and found this to be annoying also. I found a solution:
1. after logging in go to the Advance tab
2, select Administration on the left
3. select Set password
4. uncheck Password Recovery
5. problem solved
6. you'll get a warning about needing to restore to factory default if you can't remember your p/w.
- roger1955Apprentice
zambeezi wrote:Hi,
5. problem solved
