Fante1234's avatar
Fante1234
Follower
Dec 30, 2018
routerlogin.net Login problems
I have problems logging into the routerlogin.net. After filling in the (I think correct) username and password I get resent to the login page. I tried to reset my password by clicking on the cancel b...
  • antinode's avatar
    Dec 30, 2018
    > Is there another way to login, or to reset my password (and username)?
       You can reset _all_ the router settings, including the "admin"
    password.  (And then reconfigure the router manually.)  Visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "Factory Settings".
