HarryZ's avatar
HarryZ
routerlogin.net not working after disabling DHCP
Walked into a new account that was having internet troubles. Fixed the issue with their ISP. Found that there was a Netgear Nighthawk AX8, Model RAX75 "downstream" from the ISP modem. I also noticed that some of their PCs were connected directly to the ISP's modem/router, and some were connected to the Netgear . So all the PCs were not on the same subnet (the ones connected to the ISP modem were on 192.168.0.x, and the ones connected to the Netgear were on 192.168.1.x) It was not possible during the time I had there to move the Netgear physically close to the ISP modem so that all the PCs would be on the same subnet. So, I just disabled DHCP on the Netgear and let the ISP router take care of assigning IP addresses for all the PCs.
Now, I want to go back and clean up this mess.  First step I want to do is to acess the Netgear and see what the firmware level is. But, I cannot get to the administrative logon.  192.168.1.1 will not work since DHCP is turned off. I've found the IP address for the router, but when I enter that into my browser I don't get a response.  If I try routerlogin.net, I get redirected  to https://www.netgear.com/home/services/routerlogincom/.
I've tried both ethernet connected and wifi. Both fail.
I tried the Andriod app, but it wants to reconfigure the router instead of just showing me what the current situation is, and I don't want to bring down their network at this time. Which also means that doing a factory reset is not on the table right now, either.
So, how can I get to the router login window?  Do I need to add a port number to the IP address?  Some other secret way of doing this?
Thank you for your assistance,
  • > [...] I will try connecting the cable from the Technicolor to the LAN
    > port on the Netgear and see what happens. [...]
       I wouldn't do that.  That was a possible explanation for what you
    reported, not a suggested course of action.
    > [...] look in the User Manual for "Set up the router as a WiFi access
    > point". [...]
       Still my advice.
  • > [...] I just disabled DHCP on the Netgear and let the ISP router take
       Not completely wrong, but not good enough.
    > [...] Some other secret way of doing this?
       So well hidden that you might never guess the key...
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "Reset" and/or "Factory Settings".
       When that's done, and you can again get to the management web site,
    look in the User Manual for "Set up the router as a WiFi access point".
    (That will, among other things, disable the DHCP server on the RAX75.)
    • HarryZ's avatar
      HarryZ
      Aloha antinode . Mahalo (thank you) for the response. But a couple of things...
      "...Not completely wrong, but not good enough."   Care to explain a little more?
      Also, I know what a Factory Reset is, and how to do it. I thought I made it clear that a Factory Reset is not what I'm looking for.  So, do you know how to access the router admin in my current situation?
      Harry Z
      • antinode's avatar
        antinode
        Guru
        > [...] Care to explain a little more?
           What you want is to configure the RAX75 as a WAP.  A part of that
        task is to disable its DHCP server, but that's only a part of it, not
        the whole job.
        > [...] I thought I made it clear that a Factory Reset is not what I'm
        > looking for. [...]
           Yes, but I skipped right past that, assuming that with no DHCP server
        running on the RAX75, little else would be working among the devices
        connected to it, so that a settings reset would be relatively painless.
        Which would be even more likely after any existing DHCP leases expired,
        and could not be renewed.  (Also, if you didn't know what a poor idea
        disabling the DHCP server was, then I wouldn't bet that you hadn't
        committed some other configuration blunder(s), so that a settings reset
        would be a good idea, generally.)
           But, fine.
           I would not expect the (unspecified) "ISP router" to be able to do
        that.  DHCP uses broadcast messages, and those generally don't get from
        the LAN side of a router to its WAN/Internet side (where the remaining
        DHCP server resides).
           A possible exception would be if the connection between the
        (unspecified) "ISP router" to the RAX75 was made using a _LAN_ port on
        the RAX75.  And that seemed unlikely if client devices connected to the
        RAX75 had been getting addresses on a different subnet ("192.168.1.*").
        > [...] 192.168.1.1 will not work since DHCP is turned off. [...]
           Disabling the DHCP server, by itself, would not shift the RAX75 LAN
        IP address from its default of "192.168.1.1".  What I _would_ expect to
        happen would be that a DHCP-using computer which was connected to it
        would not get valid IP parameters (because there's no local DHCP
        server).
           "will not work" is not a useful problem description.  It does not say
        what you did.  It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
        > [...] I've found the IP address for the router, [...]
           How?  What, exactly, did you find?  If you found this (mystery)
        address on the (unspecified) "ISP router", and it's on the "192.168.0.*"
        subnet, then I'd guess that that's the address of the WAN/Internet
        interface of the RAX75.  Normally, that wouldn't work because the RAX75
        would see an attempt to connect to its WAN/Internet port as "remote",
        and "Remote Management" is disabled by default.
        > [...] If I try routerlogin.net, I get redirected [...]
           "try" from where?  There are multiple reasons for a computer to get
        to that misleading/useless error page, generally involving use of a DNS
        server other than the relevant Netgear router.  See, for example:
              https://community.netgear.com/t5/x/x/m-p/1976674
           If the RAX75 WAN/Internet port is connected to the (unspecified) "ISP
        router" LAN, then I'd expect its LAN interface still to be at
        "192.168.1.1".  And, if you connected a computer to it (probably by
        Ethernet), and configured that computer's network interface manually,
        using parameters like:
              Address: 192.168.1.x   (x = something big, perhaps 200?)
              Subnet mask: 255.255.255.0
              Gateway: 192.168.1.1
        then, I'd expect a web browser on that computer to be able to reach the
        RAX75 management web site at "192.168.1.1".  And you could re-eenable
        its DHCP server.  And/or configure the RAX75 as a WAP.  Which I'd expect
        to disrupt the RAX75 LAN client devices about as much as a settings
        reset on the RAX75 would have done, because they'll all need to get new
        IP configurations on the "192.168.0.*" subnet.
           Hence, I'd suggest a settings reset, and then configuring the RAX75
        as a WAP.  But, "If a man wants to carry the cat home by the tail, I say
        let him.  That cat will teach him a thousand lessons which I could never
        explain."
