kjdeutin
Jun 17, 2021Follower
RS400 Reboots Itself
Hi,
I have a Netgear RS400 that randomly reboots itself. I have tried using different power outlets with no luck. I have tried factory reset multiple times, and it works initially, only to repeat this behavior at some point in the future. I am running Firmware version: V1.5.0.68_10.0.48
Any help on this would be great. The router is connected to an AT&T router/modem which acts as a passthrough.
1 Reply
- DarrenMSr. NETGEAR Moderator
I suggest contacting support if the unit is going bad. https://www.netgear.com/support/contact.aspx
DarrenM
