tjnintulsa's avatar
tjnintulsa
Follower
Jan 23, 2021
Running Firmware for WNDR3400v3
Downloaded Zip & Extracted WNDR3400v3-V1.0.1.38_1.0.68.chk  Type says "Recovered File Fragments" 6,813 KB
When I right click/Open, double click or Click on "Open" Drop Down Box it either asks for an app or gives me a Link to the ZIP file again.  Tried to download the Genie but no luck.  Is this router TOO old for support = released 2012.  OR am I doing something wrong.  Basically a default, default computer non techie these days.  Gave up trying to figure this stuff out when I donated my XT to the local school.
  • > [...] Type says "Recovered File Fragments" [...]
       Who, exactly, says what, exactly?  Windows File Explorer?  What does
    _it_ know, other than that the file type is ".chk"?
       Who said that you should do that?
    > [...] OR am I doing something wrong. [...]
       Yup.  RTFM failure.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least). Read.  Look for
    "Upgrade the Router Firmware", and use the manual ("Locate and select
    [...]") method.
       Or:
          https://kb.netgear.com/23960
       Fine print:
          https://community.netgear.com/t5/x/x/m-p/1721037#M124018
1 Reply
       Yup.  RTFM failure.
    [...]") method.
       Or:
       Fine print:
