gyves1
Aug 09, 2017Luminary
S8000 Link Aggregation in LACP 802.3ad mode
Hi Everyone, I have bought a S8000, because the switch is able to manage the link aggregation (announced in product description) but I'm not sure if the S8000 can support the LACP 802.3ad mode, I...
- Aug 09, 2017
Here is a link to Netgear's recommendations.
TheEther
Aug 09, 2017Guru
According to the data sheet as well as manual, it only supports static LAG.
gyves1
Ok, thanks, which teaming mode can I use on my ReadyNAS to get the best data speed performance with th switch S8000 ?
- TheEtherAug 09, 2017Guru
- gyves1Aug 09, 2017Luminary
Many thanks!
In my case with the S8000 (static LAG), the ReadyNAS should be setup to teaming mode XOR
