Chandansatpola
Oct 16, 2018Aspirant
Same Router use as Extender Nighthawk ac3200
Hello all, i have purchase 4 Wifi router i.e. Nighthawk x6 AC3200 r8000, and i want to connect eachother as a extender, my first router is my main router and all others are connect to it vai a ...
- Oct 23, 2018
> [...] All are wireless devices. Only access points are connecte with
> wires.
And that's the reason. The access point itself sees a wireless
connection, but the router sees only the wired connection (from the
access point).
When a wireless device connects to the router's built-in access
point, the router knows that it's a wireless connection; everything else
is a wired connection (so far as the router knows).
antinode
Oct 16, 2018Guru
> [...] i want to connect eachother as a extender, my first router is
> my main router and all others are connect to it vai a gigabyte
> switch. [...]
"gigabit" switch, but what, exactly, does "extender" mean to you?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Use the Router as a
Wireless Access Point".
> [...] should i have to change the channel for both 2.5 and 5ghz
> frequency. or i should kept them same as it was...
I'd expect better results (less interference) if nearby access points
used different radio channels.
- ChandansatpolaOct 16, 2018Aspirant
yes, i use them as a access point ...
should i use same channel for all routers?
- antinodeOct 16, 2018Guru
Still true.- ChandansatpolaOct 22, 2018Aspirant
I have 1 main router and 11 ( access point router) same model.
i used same config for all routers....i.e same ssid, password, and same channel also.
but the problem is my 2.4 ghz signal are weak...signal can't break 2 walls..signal goes to zero.
channel for 2.4 ghz is Auto
channel for 5ghz (1st band ) 36
channel for 5ghz (1st band ) 149
channels are for all 12 routers
any suggestion..
