Chandansatpola
Oct 16, 2018Aspirant
Same Router use as Extender Nighthawk ac3200
Hello all, i have purchase 4 Wifi router i.e. Nighthawk x6 AC3200 r8000, and i want to connect eachother as a extender, my first router is my main router and all others are connect to it vai a ...
- Oct 23, 2018
> [...] All are wireless devices. Only access points are connecte with
> wires.
And that's the reason. The access point itself sees a wireless
connection, but the router sees only the wired connection (from the
access point).
When a wireless device connects to the router's built-in access
point, the router knows that it's a wireless connection; everything else
is a wired connection (so far as the router knows).
Chandansatpola
yes, i use them as a access point ...
should i use same channel for all routers?
antinode
Oct 16, 2018Guru
> I'd expect better results (less interference) if nearby access points
> used different radio channels.
Still true.
- ChandansatpolaOct 22, 2018Aspirant
I have 1 main router and 11 ( access point router) same model.
i used same config for all routers....i.e same ssid, password, and same channel also.
but the problem is my 2.4 ghz signal are weak...signal can't break 2 walls..signal goes to zero.
channel for 2.4 ghz is Auto
channel for 5ghz (1st band ) 36
channel for 5ghz (1st band ) 149
channels are for all 12 routers
any suggestion..
- antinodeOct 22, 2018Guru
> any suggestion..
https://community.netgear.com/t5/x/x/m-p/1652694#M107590- ChandansatpolaOct 23, 2018AspirantI got your answer...thanks for help
One more questions.
Users are connected to my access point but they are showing as wired connect ,not showing in 2.4 ghz band and 5 ghz band..
All are wireless devices. Only access points are connecte with wires.
