Chandansatpola
Oct 16, 2018Aspirant
Same Router use as Extender Nighthawk ac3200
Hello all, i have purchase 4 Wifi router i.e. Nighthawk x6 AC3200 r8000, and i want to connect eachother as a extender, my first router is my main router and all others are connect to it vai a ...
- Oct 23, 2018
> [...] All are wireless devices. Only access points are connecte with
> wires.
And that's the reason. The access point itself sees a wireless
connection, but the router sees only the wired connection (from the
access point).
When a wireless device connects to the router's built-in access
point, the router knows that it's a wireless connection; everything else
is a wired connection (so far as the router knows).
Chandansatpola
Oct 23, 2018Aspirant
I got your answer...thanks for help
One more questions.
Users are connected to my access point but they are showing as wired connect ,not showing in 2.4 ghz band and 5 ghz band..
All are wireless devices. Only access points are connecte with wires.
One more questions.
antinode
Oct 23, 2018Guru
> wires.
access point).
