Itsall4fun's avatar
Nov 22, 2017
Samsung Blu-ray player says the HTTP port is disabled
I am trying to connect my wired Samsung Blu-ray player to the internet and I keep getting the message that the HTTP port is disabled. I have tried assigning its own IP address and also entering the router settings manually into the player. Nothing works, so I’m looking for suggestions.
  • I installed a firmware update for the blu-ray player onto a flash drive and updated the player through that and it connected again finally. Guess the new router was not compatible with it before the update. I would try that.
  • I just Googled "Samsung Bluray http disabled"' and found this interesting link on another forum.  Looks like either manually configuring a DNS server address on the Blu-Ray player or manually configuring a static IP, gateway address and DNS server address works.
    • Itsall4fun's avatar
      Itsall4fun
      Guide
      Hi thanks, I read that same post and tried everything it suggested to no avail.
      • TheEther's avatar
        TheEther
        Guru
        Can you provide some details about what you tried? Did you manually enter a DNS server address on the player? What address did you enter?
        Did you try entering a static IP address as well as a gateway address? What did you enter?
        Is your player obtaining an IP address from the router?
