bobnfran's avatar
bobnfran
Follower
Jan 22, 2022
Securiy Key R7000p
Brand new and very tech-challenged.  How do I find security key for to connect new router.  Scanner did not work for me. All help is appreciated.  Thanks in advance, Fran
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Start by explaining the problem and what you are trying to do.
    What is asking for a "security key"?
    What does "Scanner did not work for me" mean?
    If you are talking about the wifi "passphrase"(password), look at the label on your router.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
