Fce
Apr 25, 2022Follower
Seems like my Local access is gone. Now, I have anywhere access, which I can not run speed test,
I have no idea what caused this problem. Everything was working fine last week? Router R7900P . Firmware is up to date.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How are you connecting to the router? Wired or wireless?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network. - michaelkenwardGuru - Experienced User
Any chance of explaining what the problem is?
Burying question in a long subject is a bad idea. Not enough room for a proper description.
What are you doing and where does it go wrong?
Is this something to do with using an App with your device?
That's what Anywhere Access is about.
Which app? Android? iOS?
Sadly, " up to date" is not a reliable guide. A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
