swilly2012
Aug 10, 2021Tutor
Server certificate cannot be trusted (Nighthawk R7000)
Hi,
Hoping someone can help me understand why all of sudden my internet stopped working. I have a Nighthawk AC1900 (R7000) and when I try opening YouTubeTV, HULU, AmazonPrime, etc... I get an error that says "Server Certificate cannot be trusted. Please contact content provider".
When I try to connect via my phone, I get this error message "Cannot Verify Server Identity". "The identity of "m.hotmail.com" cannot be verified.
I do have a hotmail account, but I don't understand what is going on.
When I try to connect to my router through the app on my phone, I'm unable to connect wirelessly. I try to "connect via Anywhere Access" and it says my router is disconnected.
I have unplugged and rebooted the router many times with no change.
Is this an issue with the router, or is it with my internet provider?
Thank you for the feedback.
what modem/gateway do you have?
What firmware is on the router?
- I don’t have a modem/gateway. My internet provider is Windstream Kinetic (dish). There is a cable going from the satellite dish to a POE. Then a LAN goes to the router.
I can’t tell what version the router is on. I’m unable to access it through my phone app.- plemansGuru - Experienced User
does it work directly connected to the windstream dish?
