divor
Sep 18, 2016Aspirant
Setting up a new Nighthawk R7900 router
Just bought a new Nighthawk x6 R7900 and it asks for my "Security Key" or "Passphrase" which I enter but it says it doesn't match the security key for this network. Any suggestions?
- Sep 18, 2016Yes that is what I was trying to do. So now I went with your suggestion and it worked. Thank you!
So if I disconnect the Ethernet cable will the laptop automatically stay connected to the router?
netwrks
Sep 18, 2016Master
Are you attempting to configure the router using wifi? If yes, don't.
Connect to the router via an Ethernet cable. That way you can modify the config, without second guessing whats going on. And you should be able to view the passphrase that is currently configured in the router. Barring all that I said, reset to factory default and start over, using an Ethernet cable to connect to the router.
