divor's avatar
divor
Setting up a new Nighthawk R7900 router
Just bought a new Nighthawk x6 R7900 and it asks for my "Security Key" or "Passphrase" which I enter but it says it doesn't match the security key for this network. Any suggestions?
  • divor's avatar
    Sep 18, 2016
    Yes that is what I was trying to do. So now I went with your suggestion and it worked. Thank you!
    So if I disconnect the Ethernet cable will the laptop automatically stay connected to the router?
