divor
Sep 18, 2016Aspirant
Setting up a new Nighthawk R7900 router
Just bought a new Nighthawk x6 R7900 and it asks for my "Security Key" or "Passphrase" which I enter but it says it doesn't match the security key for this network. Any suggestions?
- Sep 18, 2016Yes that is what I was trying to do. So now I went with your suggestion and it worked. Thank you!
So if I disconnect the Ethernet cable will the laptop automatically stay connected to the router?
divor
netwrks
Sep 19, 2016Master
If you have wifi enabled on your laptop, your laptop should stay connected to the router, if you rare correctly authenticated wirelessly.If not, you should re-visit your router and laptop wifif configuration..
