tzett's avatar
tzett
Follower
Jun 14, 2021
Setting up port forwarding for Minecraft server
Hello,
I am trying to setup a Minecraft server using portforwarding so my friends can connect. The server works and I can connect locally using my ipv4 address. I got this from running ipconfig in cmd. I found my IP from googling "whats my ip" and that matched what was displayed in my advanced settings. My ip is 96.35.x.x
I set up port forwarding through my routers advanced settings and used the same ipv4 address that I used to connect locally. This should not be the issue.
I checked to see if the port was open using "https://www.yougetsignal.com/tools/open-ports/" and after inputting my public ip address (96.35.x.x) and the port (25565) the website said it was closed. I also know it isn't working because my friends could not connect using my public ip address.
If it helps I am using ethernet and my ISP is Spectrum.
Please get back to me as quick as you can!
Thanks.
1 Reply
  • > Model: WNDR3400v2|N600 Wireless Dual Band Router
       Firmware version?  Connected to what?
    > [...] my ipv4 address. [...]
       What is it?
    > [...] I got this from running ipconfig in cmd. [...]
       So, not your _personal_ IP address, but the LAN IP address of (an
    Ethernet interface on) some (Windows) computer or other on your LAN?
    > I set up port forwarding through my routers advanced settings [...]
       I can't (yet) see your pictures.  In-line images must be approved
    by a moderator before others can see them.  The time required varies.
    Attachments have no such limitation.  Of course, attachments have their
    own one-per-message limitation.  In the mean time, copy+paste is your
    friend.
    > I checked to see if the port was open using [...] and after inputting
       You, _personally_ have a public IP address?  Or is that the
    external/public IP address of some interface on some device at your ISP
    or your dwelling?
       Even more helpful would be information about your modem (or
    modem+router), or whatever's between the WNDR3400v2 and your ISP.
       For the usual problems with port forwarding, see:
          https://community.netgear.com/t5/x/x/m-p/1859106
