karlo88
Apr 30, 2021Tutor
Setting up Port Triggering for Port Forwarding
My RangeMax recently failed and I replaced it with a ProSafe FVS318N. I understand the former is for home use and the latter is for business. On the RangeMax, I had Port Forwarding set up for a video monitoring system, one with a specific IP address. On the ProSafe, Port Forwarding is not an option. I only see Port Triggering. How do I set up PortTriggering and the router to perform Port Forwarding for the monitoring system? Thanks.
> [...] On the ProSafe, Port Forwarding is not an option. [...]
Says who?
> [...] I only see Port Triggering. [...]
When you looked _where_, exactly? "I don't see it" and "It doesn't
exist" are spelled differently for a reason.Here's a radical concept which works for some people:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the Reference Manual (at least). Read. Look
for "Inbound Rules (Port Forwarding)"?I've never touched a FVS318N, and I can't see your old
port-forwarding rules, so I know nothing, but "Send to LAN Server" looks
to me like the desired option (perhaps with "Translate to Port Number").- karlo88Tutor
The RangeMax setup page is attached. One can choose between Port Forwarding and Port Triggering
The ProSafe is only for Port Triggering. There is no option on that page, nor another page, for Port Forwarding
I am seeking someone to help me setup the ProSafe step by step to accomplish Port Forwarding. I am guessing that it has something to do with associating certain LAN IP addresses to ports and opening those ports to those IP addresses.
- karlo88Tutor
