Whoisd3v
Jul 01, 2019Aspirant
Several Questions..
Basically I have this issue where my signal for gaming is weak because our family modem is a floor below me. So I've been looking into finding anything that'll make that signal stronger: i.e. an extender, repeater, etc. I recently bought a Nighthawk 6700 but returned it being that it wasn't capable of being bridged or used as an extender. I needed something I could use in either mode so that I could have the wifi booster upstairs in my room, closer to my ps4 to maximize the strength. My first question is; Knowing this info, do you guys think I'd be better off getting a repeater? Or a router capable of bridge mode?
I got my R6900P today, since it was capable of bridging. I set it all up, in bridge mode and all, but it still didn't work with my PS4. I looked onto the wifi list and the SSID of the router wasn't even there, even after plugging it back into the modem via ethernet. When it's in bridge mode, is that supposed to happen? Does bridging the connection basically infuse the router into the modem's internet connection? If so, do I connect to the modem's wifi connection instead?
I'm not the biggest tech head on earth, but I know a little bit about these things, I just need answers since I can't seem to find any clear cut answer anywhere else. I need to knwow what I'm doing wrong
- That’s exactly what it was, schumaku. I had my ethernet plugged into the LAN the entire time. Plugged it into one of the ethernet ports and viola! Worked like a charm. Thanks for that, now I know for sure how bridge mode works in the future.
Speaking of future, I’ll be moving pretty soon. I’ll probably be switching ISPs, which would probably require that I’ll need to edit my bridge settings towards a newer router. How would I go about taking it out of bridge mode if that’s the case?
Whoisd3v wrote:
My first question is; Knowing this info, do you guys think I'd be better off getting a repeater? Or a router capable of bridge mode?There is nothing better than a network cable (or a fiber) - worth every effort to install an Ethernet cable connection and configure whatever device (consumer routers make poor wireless access points however) as a wireless access point once wired. Wireless technology does not - never - replace a cable. Even if the Mobile Internet 5G industry does try to convince us.
Whoisd3v wrote:
I got my R6900P today, since it was capable of bridging. I set it all up, in bridge mode and all, but it still didn't work with my PS4. I looked onto the wifi list and the SSID of the router wasn't even there, even after plugging it back into the modem via ethernet. When it's in bridge mode, is that supposed to happen?Not sure you got it right: A wireless bridge does establish a wireless connection from the R6900P to your existing wireless just like a mobile phone or tablet would do from the upper floor. The connection to the R6900P in bridge mode must go to the LAN port(s). It's not a wireless extender of any kind, it does not serve as a wierless AP at the same time handling the bridge.
- Whoisd3vAspirantThat’s exactly what it was, schumaku. I had my ethernet plugged into the LAN the entire time. Plugged it into one of the ethernet ports and viola! Worked like a charm. Thanks for that, now I know for sure how bridge mode works in the future.
Speaking of future, I’ll be moving pretty soon. I’ll probably be switching ISPs, which would probably require that I’ll need to edit my bridge settings towards a newer router. How would I go about taking it out of bridge mode if that’s the case?- schumakuGuru - Experienced User
Probably the most easy way is to do a factory reset, and re-configure your R6900P from scratch into the mode desired (router, wireless bridge, or wireless access point [wired]).
