mslotnic's avatar
mslotnic
Should I install Netgear Smart WiFi A 2300 R7000P Router?
I just purchased a Netgear Nighthawk router.  I then learned that the model is vulnerable to VNPFilter malware.  I now wonder if I should look for a different router that would be more secure.  I’d appreciate opinions. Thank you
    • mslotnic's avatar
      mslotnic
      Thank you for your informative reply.  I’m just wondering if Netgear is confident that the product is well,protected if the guidance is followed or, rather, if Netgear recommends an alternative Netgear router as less vulnerable.
      Blanca_O wrote:
      Hi mslotnic,
      Please be advised that NETGEAR is aware of a piece of malware called VPNFilter that might target some NETGEAR routers.
      Here's a reference link for the Security Advisory for VPNFilter Malware on some Routers:
      https://kb.netgear.com/000058814/Security-Advisory-for-VPNFilter-Malware-on-Some-Routers
      I suggest to perform the recommended steps to protect against this possible malware.
      • Blanca_O's avatar
        Blanca_O
        NETGEAR Employee Retired
        Hi mslotnic,
        NETGEAR values the security of your network and we strongly suggest that you do the following as indicated on the KB link:
        - Install latest firmware (1.3.1.26)
        - Change default admin password
        - Turn off Remote management
        Rest assured that the team is doing an investigation and we will provide update once new information will be available.
