rwsinky's avatar
rwsinky
Simple question
Managed to stumble through the setup for this new router and all is working well. This may be a dumb question but when I look at the available wireless connections on my PC I have several. There is a...
  • rwsinky's avatar
    rwsinky
    Jun 17, 2016
    I found what I needed and it is in the Genie BUT it's a vertical tab that is kinda obscure. That did the trick. Thanks for the help guys!
    Russ
