MWD1984
Aug 02, 2015Aspirant
Slow download speeds Xbox one (WIRED)
Hi All, Since I got the Netgear R7000 Nighthawk my Xbox one has got terrible wired download speeds Most of the time it's between 6-10 mbit. When I check my connection (works just like speedtest.n...
- Aug 10, 2015Thanks for your reply. I think I found a solution to my problem. One day I deleted my automatic DNS settings and put Google's DNS in my Xbox. Now I get around 70-90 Mbit, instead of the 6-10 mbit. Still not how it used to be but LOADS better than the past weeks. How is it possible that the auto settings for DNS are broken for me? Just when I thought I knew everything about routers/computers/internet I stumble upon new problems haha
netwrks
Aug 02, 2015Master
If you have QoS enabled on the router, disable it, and try again.
