MWD1984
Aug 02, 2015Aspirant
Slow download speeds Xbox one (WIRED)
Hi All, Since I got the Netgear R7000 Nighthawk my Xbox one has got terrible wired download speeds Most of the time it's between 6-10 mbit. When I check my connection (works just like speedtest.n...
- Aug 10, 2015Thanks for your reply. I think I found a solution to my problem. One day I deleted my automatic DNS settings and put Google's DNS in my Xbox. Now I get around 70-90 Mbit, instead of the 6-10 mbit. Still not how it used to be but LOADS better than the past weeks. How is it possible that the auto settings for DNS are broken for me? Just when I thought I knew everything about routers/computers/internet I stumble upon new problems haha
MWD1984
Aug 10, 2015Aspirant
Babylon5
Aug 10, 2015NETGEAR Employee Retired
The router by default will redirect DNS queries to your ISP, so if you know your ISP DNS addresses you can substitute those where you currently have the Google addresses to see if that was the cause of your issues, just as a test of course.
