R2dTOO
Jan 12, 2019Guide
Slow internet when connected to Wifi
I just got AT&T 1000Mbps fiber internet, as well as an R7000 Nighthawk router. The AT&T RG is in passthrough mode, and the Nighthawk is in router mode. Nighthawk is running firmware version 1.0.9.60_...
- Jan 14, 2019
OK. I think I have solved the problem. Here is what I did:
- I got rid of the AT&T Gateway. It's now just the Nighthawk connected to the AT&T ONT via a switch in the middle. Instructions here if anyone is interested.
- After getting rid of the gateway, I factory reset the router again. I set the SSIDs up again, changed the 2.4GHz and 5GHz channels from "Auto" and whatever the default 5GHz channel was to "06" and "161" (looking at a wifi analyzer, revealed that channel 6 was the least congested in my area for 2.4GHz. Channel 161 was not used at all in the 5GHz spectrum).
After doing both of these things, I am now getting between 350Mbps and 525Mbps on the 5GHz network.
I had done step 2, with the gateway in place, several times before. I think the combination of the two together is what solved my issue.
Thank you everyone for the help.
R2dTOO
Jan 14, 2019Guide
Yes. I did a factory reset.
R2dTOO
Jan 14, 2019Guide
