dimab0's avatar
dimab0
Follower
Jan 06, 2017
Slow speed suddenly on R8000
I've been using this router for about 1.5 years now. As of 2 days ago, my download speed seems capped to 7Mbps, while the upload goes up to 20Mbps. Directly through out wired connection in the wall, not using the router, I am getting 200 / 200 Mbps for down and up.
What can I troubleshoot? Nothing has changed at all this week. I have tried to unplug and plug back in the router, but there is no effect. I did a hard reset and used default router settings and still get the same effect. Is there anything else to try? I can't believe that I suddenly have a broken $300 router....
  • Hi dimab0,
    1. What is the firmware version of the router?
    2. Disable QoS and check if the same.
    3. Use a different ethernet cable.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi dimab0,
    We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
  • JamesGL's avatar
    JamesGL
    Hi dimab0,
