Retired_Member
Jan 21, 2017Slow transfer speed to rcloud
Couldnt find a specific forum for rcloud. i've a question for the community: is there a known issue with very slow transfer rates over the web between an R8000 and the rcloud app on iphone? i'm usi...
- Retired_MemberJan 21, 2017
Just an update, today the speed improved dramatically and I'm currently able to browse my photos in a reasonable timeframe. I have no idea whats changed but its not my setup. I think the hardware (router and USB HDD) must be ok and the issue rests somewhere else. I'm going to assume its a readyshare server issue and performance depends on the time of day.
If they cant provide a consistent experience then I'm going to stop using it.
I'll update this thread later.
Retired_Member
Jan 21, 2017Just an update, today the speed improved dramatically and I'm currently able to browse my photos in a reasonable timeframe. I have no idea whats changed but its not my setup. I think the hardware (router and USB HDD) must be ok and the issue rests somewhere else. I'm going to assume its a readyshare server issue and performance depends on the time of day.
- Retired_MemberFeb 10, 2017
Ok, the issue is with the Rcloud service and not my router or the USB 3.0 HDD.
Rcloud is very unreliable and inconsistent. Occassionally it performs well but more often than not it just sucks.
There are far too many times when its way too slow or just times out,
It seens to buffer up files by trying to download in advance which I think is a very flawed approach as I dont necessarily want to retrieve the files it picks. This buffering is reducing responsiveness.
Because I live in the southern hemisphere its possible they're running housekeeping tasks just when I'm using it, but I'm guessing, whatever the issue its an exercise in frustration and I cannot recommend the service to anyone.
- StephenBFeb 10, 2017Guru - Experienced User
Is your iPhone connected to your local WiFi network, or are you transferring over cellular? ReadyCloud does connect through Netgear Cloud Servers if you aren't connected to your home network, but it should be doing a direct transfer if you are on your home network.
