sblomeke's avatar
sblomeke
Follower
Mar 04, 2017
Slow WiFi Speed on Nighthawk R8000
Hello, i have Comcast Blast Internet 150MB. My setup is a Netgear N600 Modem/Router with wifi disabled and my Nighthawk R8000 plugged into that. My direct connect wired connection to the N600 gets 18...
  • ddeckerx's avatar
    ddeckerx
    May 15, 2017
    It turns out the problem was attributable to Comcast. They symptoms made it appear that it was the router, but Comcast determined it was their exterior lines and they put a filter on the line coming into my building and that took care of it. Now I'm getting 180mbps through the both the Nighthawk router and the Xfinity gateway! Thanks.
